Display CPU use
TFF
Unread post by TFF » 22 Aug 2011, 00:50
Hi. I'm trying to test various methods of achieving the same goal. What I was hoping to do was average out how much CPU use was reported over time for each patch, and compare that way. But as far as I can tell, there is no module that outputs CPU use. Is there anyway to accomplish what I'm after?
Best,
-Zach
CleverConQueso
Unread post by CleverConQueso » 22 Aug 2011, 04:55
Take a look at 'Dashboard'. You can queue the output to an array and take the average of the array.
Unread post by bsork » 22 Aug 2011, 08:27
Just remember that the Dashboard CPU meter shows the total usage for the machine - AFAIK it's the same value as in the Task Manager.
Unread post by nay-seven » 22 Aug 2011, 08:46
the new module current patch settings is what you're looking for.
CleverConQueso
Unread post by CleverConQueso » 22 Aug 2011, 16:30
How cool - so we can use 'Current Patch' to performance optimize patches.
TFF
Unread post by TFF » 22 Aug 2011, 19:29
Ah, fantastic. Thanks for the tip.
Users browsing this forum: No registered users and 911 guests
