Midi routing
noise2sine
noise2sine
hello,
please helpp!!!!!
After reading few post, i was thinking using Mapple Midi, but is there a possibility just by routing ( i would prefer) ? and how ??
Thank u!!
please helpp!!!!!
Thank u!!
I'm not sure how Live works, but in Reaper for an example you can simply select what to record - audio/midi in/out, etc.
In the Bassliner patch you have to add and connect a MIDI out module.
This is at least how I could make it work.
best way : don't use Live...
second way : 2 things to do :
first add a midiout on the out inlet of the Swing It! script module in the bassliner patch
second : in Live add a midi track and choose usine vst as midi in for this new track...et voila...
noise2sine
thank u so much guys,
i agree with u Nay Seven, using Live it's a bit like eating Mc Donalds : U know it's bad but can't help doing it! Whereas Usine it's more like real Bio Food from the "terroir" but need more time to cook.
Slowly i 'm moving my organisation to Usine!!! i'm waiting for the 4.0 version
Don't feel so alone, my friend! We all are waiting in the cold and rainy and windy night!noise2sine wrote:i'm waiting for the 4.0 version
vincent michel
composer & novelist
composer & novelist
captain caveman
Sorry for bumping this old post, but I need 1 post before starting a thread and my question is about Bassliner.
I am a bit confused, is the "add octave bass" button supposed to play the same sequence an octave higher? What is happening here is that the higher octave is offset in time too from the sequence.
yes, this switch " Add a bass line an octave higher and shifted by half duration to create more complex patterns. "
( most of patch in Usine have a wiki page , check the little ? in the patch window )
captain caveman
Ah, thanks nay-seven.... it was a bit late last night, I have had a look at the patch this morning and I see how it works. Merci beaucoup!
Users browsing this forum: No registered users and 486 guests
