button design and backgnd pictures loading ...
protofuse
Unread post by protofuse » 12 Aug 2011, 16:17
I design a button using a special backgnd image + a clicked image too.
ok it works.
If I decide to change one of the image but keeping the same name, I have to quit Easine, restart it.
All the same.
The cache is nice, but annoying in that case.
Unread post by senso » 12 Aug 2011, 16:44
It's more than a cache: images are stored in a "image pool" associated with the patch.
So nothing to do to help you.
protofuse
Unread post by protofuse » 12 Aug 2011, 16:59
oh..
okay.
so there is no solution excepted to rename the pic?
I can work around this like that no prob.
thx for the feedback.
Unread post by senso » 12 Aug 2011, 18:06
sorry actually not.
in the V6 things will be probably improved.
Unread post by woodslanding » 12 Aug 2011, 18:16
Wait-- if you go and reselect the BPM file from the layout window in usine, you can see the new button graphic. Even if it has the same name as the old one.
Am I missing something? Iis this different in Easine?
Well, I am going to check out easine for the first time, I guess I'll find out!
protofuse
Unread post by protofuse » 12 Aug 2011, 18:23
woodslanding wrote:Wait-- if you go and reselect the BPM file from the layout window in usine, you can see the new button graphic. Even if it has the same name as the old one.
I tested before, it didn't work anymore.
I make something: quit/restart usine, now it works.
I'm cursed!
Users browsing this forum: No registered users and 104 guests
