Loop recorder with the piano roll
noise2sine
My request is to be able to record midi loops or midi sequence on time. I'm using two tracks. The first is a 4 bar midi loop with a simple beat used as a metronome and the second track is used for the takes.
- the problem i'm facing, is when i press rec on the piano roll, i can see that recording doesn't start from the begining of a bar even if i quantize the rec button to "bar".
- When i did this test, what i have recorded doesn't correspond to what is played. the initial pattern is just quavers (croches) on 4 bars and the recording are quavers but not recorded at the right place within the bar.
- Is there somewhere an existing patch close to what i want ?, i just want to start a recording at the beginning of a bar in order to rework easily the takes.
Cheers,
Cheers,
hello,
you'll check today but i think the piano roll has been improved in the new version .
noise2sine
Hello Nay,
I have just tested the super great new version and i made the same test as described above. It's better for sure but not perfect.After recording one bar filled with quavers, i have one semi quaver empty space at the begining of the recording. Therefore all the take is not accurate "barwise". I just need to edit a little bit to make it accurate. Do u think it will be fixed soon ?
the accuracy of midi recording in usine seems to be good.
So maybe more a matter of patching, PianoRoll settings or setup/bloc size?
see the test patch http://www.sensomusic.com/forums/upload ... %20rec.pat
noise2sine
Is there any special trick for saving MIDI files when recorded in the piano roll ?? i have 4 bars recorded and i saved it. When i reopen it i have just the first beat of the first bar recorded ? Any trick there ?
can't reproduce this right now
can i have more details
you have this problem in pro version rc2?
you choose how many midifiles at first..?
noise2sine
Hello Nay,
i'm using Rc1 Pro Version.I'm using the patch you made "mustang midi guitar". I'm using the 16 midifile piano roll.
ok, will test , but RC4 is coming...
noise2sine
Hello Nay,
i have just tested the RC4 version and i'm facing the same problem. I have recorded 2 bars with the piano roll, then i have saved it and finally reopen the midi file which was previously saved: the notes don't have the same length ! . Right now saving a midi file will change its length.
What am i doing wrong ?
ok, I'll try again then
hello, a new version will be out today, i can't reproduce exactly the same problem than you, but first cut notes bug have been resolved, hope it will be ok for you too
noise2sine
thank u Nay ! but it's not only the first note that are cut but the whole midifile. In other words the save as function change the whole midi file.
Users browsing this forum: No registered users and 349 guests
