a very basic groove box
joffo78
Unread post by joffo78 » 03 Aug 2011, 09:30
Hi
if you're beginners have a look of my simple groove box i made very simply:
http://www.sensomusic.com/downloadaddon ... OVEBOX.pat.
Is it possible to get the number of download for the addons ?
Unread post by nay-seven » 03 Aug 2011, 10:00
Really cool one Joffo
quick test : little problem at first with the delay, give me some bad sounds when i open
suggestion: textfield as name of each part , can also be a on/off switch , easy to mute quickly some parts..?
will check deeper later
but thanks, it's a good addon
number of download are only visible in stats actually
joffo78
Unread post by joffo78 » 04 Aug 2011, 16:57
I update my addon here mr groove box 01
now you can record anything and apply a slice detection .
you can also see a video demo on this channel :
http://www.youtube.com/user/jeanfr011275
regards
AstralV66
Unread post by AstralV66 » 04 Aug 2011, 17:15
I'm just starting out with Usine (eagerly awaiting version 5.7) and took a look at the video to see if it would be useful to help teach the ways of Usine.
I doubt I'll understand a lot of the work that is probably in this, but hopefully that will change over the coming months.
Thanks for this joffo78, a real inspiration for me.:)
joffo78
Unread post by joffo78 » 04 Aug 2011, 17:49
thank you.
i'd just upload a new version where the numbre of step of each parameters follows the cycle lengh
try to compare to modify de lengh of the cycle
Users browsing this forum: No registered users and 2 guests
