Hi mates,
can we resize the UI elements without using the mouse ..?
I mean, can we change the size & the position by using some constant defined somewhere in the patch, in an hidden menu related to the UI element or even by scripting ?
can we align UI elements easily ?
best,
Size & Position of UI elements ?
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
One day all UI parameters will be accessible as the controls ones, but it's not implemented yet
got it!
(btw,it was more a question on "how can I do better than I'm doing ?" than a suggestion.. of course, actually, it is TOTALLY ok!)
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
no problem,
about align layouts, there's also the grid function in the layout window, setting the good size and click in the background can help
There are two iml commands u can access via script or sendmsg module:
Set_ctrl_pos and set_ctrl_size.
thanks a lot23fx23 wrote:There are two iml commands u can access via script or sendmsg module:
didn't explore yet IML messages
but I got it, using analogy with other patching system in my head :/
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
Users browsing this forum: Bing [Bot] and 15 guests
