PNG with transparency support for background is very missing.
But maybe, I missed something myself.
Using knobman (but illustrator for panel design too), I can export as BMP with alpha but it doesn't work well :-/
cheers,
PNG with transparency support for background ... please ?!
julien
julienbayle.net
designthmedia.com
soundcloud.com/protofuse
_ _ _ _ _ _ _ _ _ _ _ _ _
Ableton Certified Trainer
julienbayle.net
designthmedia.com
you' don' t miss anything cause this not implemented yet , so it's a post for the suggestion forum...?
I had asked for transparency option in edit layout, but the answer was that it is not senso priorityprotofuse wrote:Hello,
cheers,
for sure, considering the VSTexport feature they will release, it can be considered as a low priority
but they will do it for sure... I guess!
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
I think "export as VST" is not priority for usine too, because it is not for usineprotofuse wrote:for sure, considering the VSTexport feature they will release, it can be considered as a low priority
export as VST is not for Usine ....?
I guess you cannot imagine the revolution for Usine itself after that
I mean, actually, there is NO SynthMaker concurrent on the market.
Tomorrow, there will be one, and not the less: USINE.
it will change all (and we'll have our png transparency for sure
julien
julienbayle.net
designthmedia.com
julienbayle.net
designthmedia.com
Users browsing this forum: Bing [Bot] and 130 guests
