PNG with transparency support for background ... please ?!
protofuse
Unread post by protofuse » 03 Aug 2011, 22:02
PNG with transparency support for background is very missing.
But maybe, I missed something myself.
Using knobman (but illustrator for panel design too), I can export as BMP with alpha but it doesn't work well :-/
cheers,
Unread post by nay-seven » 03 Aug 2011, 22:24
you' don' t miss anything cause this not implemented yet , so it's a post for the suggestion forum...? :)
r.erorr
Unread post by r.erorr » 04 Aug 2011, 00:17
protofuse wrote:Hello,
cheers,
I had asked for transparency option in edit layout, but the answer was that it is not senso priority :(
protofuse
Unread post by protofuse » 04 Aug 2011, 09:44
for sure, considering the VSTexport feature they will release, it can be considered as a low priority :|
but they will do it for sure... I guess!
r.erorr
Unread post by r.erorr » 04 Aug 2011, 23:02
protofuse wrote:for sure, considering the VSTexport feature they will release, it can be considered as a low priority :|
I think "export as VST" is not priority for usine too, because it is not for usine ;) Usine works fine without VST export too :)
protofuse
Unread post by protofuse » 05 Aug 2011, 14:09
export as VST is not for Usine ....?
I guess you cannot imagine the revolution for Usine itself after that :P
I mean, actually, there is NO SynthMaker concurrent on the market.
Tomorrow, there will be one, and not the less: USINE.
it will change all (and we'll have our png transparency for sure :P)
Users browsing this forum: No registered users and 118 guests
