Usine 5.7 VST channels
jean-marc duchenne
Unread post by jean-marc duchenne » 27 Jul 2011, 10:01
I have just seen the (too soon ?) announce of Usine 5.7 in KVR forum.
The VST export is wonderful, BUT, when I read the comparison chart, I see that the number of in/outs for the Pro version is limited to 2 channels ???
I suppose that it is a mistake, since for Easine it is written 8...
You mean 32, no ?
joffo78
Unread post by joffo78 » 27 Jul 2011, 10:31
vst export is a great news !
where can we find this wonder ?
Unread post by nay-seven » 27 Jul 2011, 10:50
Yes, a user has viewed the wiki page and spread the information before the official announcement..
but we hope have this version ready, for the end of this week.
About the pro vst i check with Senso
multiphone
Unread post by multiphone » 27 Jul 2011, 11:58
Hello Jean-Marc !
As i know for the moment the VST export from Usine V 5.7 Pro are only stéréo right.
But the VST export from Easine are already 8 chanels. I supose the multichanel VST export from Usine pro is just a question of time.
Yes a 32 channels version would be great but is not so easy i supose.
I let senso awser.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
TFF
Unread post by TFF » 28 Jul 2011, 16:46
I am stoked about this new VST export function. Out of curiosity, how lightweight is Usine Reader?
Unread post by nay-seven » 28 Jul 2011, 17:07
yes, we plan to propose a free dll example to download soon , this way you can check yourself.
but this also depend of the composition of your original patch, example with wave files included...
I've for example a simple patch without sample and the reader folder is about 15 Mo and the Dll is around 4Mo
jean-marc duchenne
Unread post by jean-marc duchenne » 28 Jul 2011, 18:18
If I understand well, but I will see myself soon, the plugins (dll) are not selfcontaining but they need the player, like with the old Max/Msp 4 runtime ?
I suppose also that the reader has to be downloaded / installed only one time.
Unread post by nay-seven » 28 Jul 2011, 19:22
not exactly the same ,
actually , i can send you a simple dll
the first time you run it it will install his own reader , that's all
Unread post by senso » 28 Jul 2011, 20:34
Usine Pro VST has always been 2inx2out. But it was a multi 2x2 with side chaining capabilities.
The main difference now is that Usine Pro is a single 2x2 and each Usine vst is totally independent.
But now Easine is a fully 8x8 and probably 16 or 32 soon.
jean-marc duchenne
Unread post by jean-marc duchenne » 29 Jul 2011, 08:56
OK, so I will simply use Easine instead of Usine, no problem.
But where is the Interface Bilder in Easine ?
Unread post by senso » 29 Jul 2011, 09:27
Easine is only in IB mode!!!
lalo
Unread post by lalo » 29 Jul 2011, 11:19
senso wrote:Usine Pro VST has always been 2inx2out. But it was a multi 2x2 with side chaining capabilities.
great! VST version is a great thing for integration with other stuff.
But would be really useful to get Usine generated VST to have multiple in/out to take advantage of the great usine features.
i.e. multiout oriented VST as drum machines ( different output for every drumset piece), or multichannel loopers/samplers
a.
multiphone
Unread post by multiphone » 29 Jul 2011, 11:27
Yes ! good news.
I think that this is not a problem if Usine VST Pro does not export 32 channels.
Because usually if we need a VST for mutichanel composition, it is for a specific task or set of specific tasks, and to Easine organize precisely that in IB mode.
If Easine could export 32 CHANNELS VST it would be really beautifu !!!l
Just before we find (Jean-Marc and me) a specific reason that we need Usine Pro VST channels 32.
Mister + ;-)
HB
Flexinoodle
Unread post by Flexinoodle » 30 Jul 2011, 08:54
So the VST export needs a player :(
Very sad news for me
I keep coming back to check on Usine but at the moment it always seems to be one step from greatness
Will check back soon ;)
A ding dang doo
Unread post by senso » 30 Jul 2011, 09:36
Flexinoodle wrote:So the VST export needs a player ;)
the player is integrated in the a the dll.
totally transparent: a single file!
jean-marc duchenne
Unread post by jean-marc duchenne » 30 Jul 2011, 11:45
15 Mo for the Reader in EACH plugin ?
Or there will be a possibility do download the player only ONE time and give the plugins a more correct size ?
Unread post by senso » 30 Jul 2011, 12:14
I don't know where you get this information?
Maybe you should wait until the first release to make your opinion?
The size of the dll is around 4 Mo or larger if you include audio files.
jean-marc duchenne
Unread post by jean-marc duchenne » 30 Jul 2011, 13:01
I've just read it in this thread on a previous answer of Nay-Seven :*
Of course !
It was not an opinion, just a question based on the info given here.
4 Mo is nicer ;)
Unread post by nay-seven » 30 Jul 2011, 13:21
Yes, it's my fault, I forgot a word you should have read the reader temp folder is about 15 Mo
protofuse
Unread post by protofuse » 30 Jul 2011, 16:45
I'm definitively interested.
