trouble with mapper curve
here you can download a example of a patch which doesn't work :
http://www.sensomusic.com/forums/upload ... 20work.pat
it seems to be my -80 value that give trouble.
can you explain how you use it..?
or maybe better send an example by mail..? ( better for bug submission )
ok, crossed post , but your link don't work..?
in fact i want to modulate volue with a curve with point. the trouble is curve with point si a linear curve (i don't want to drive a curve to modulate my level but only have a duration for input or output).So i insert a mapper curve between curve with point and gain input.
Tell me if i can do a more simple thing.
Thank you
Thank you
not sure to follow, it's a kind of ADSR.?
not at all i want i line to make fade in or fade out.
Users browsing this forum: No registered users and 112 guests
