Does anyone know if there's a way to raise the port value maximum to a value higher than 9999? I've got a OSC wrapper that's using 12345 as its listen port. Does anyone know a trick to redirect?
- CCQ -
OSC Send and SendText Maximum Port Number
CleverConQueso
no tricks right now, but maybe Senso can increase the possible number for next version..?
CleverConQueso
<Oops. Nevermind. Found the 'string'./>
Thanks, Nay-Seven. While I'm asking, do you know if there's any plans to have OSC Receive accept string data?
no problem to increase the port number!
next release.
next release.
CleverConQueso
Thanks Senso. Works as promised.
