I'm trying to control the reset on the clock, and when I hook a button up to it, I get a reset both when the button is pushed, and again when it is released. I only want a reset on push.
I ttried 'null event if off' on the button, but that didn't work. Everything I tried with OIC and Freeze event modules still triggers on the release.
I'm sure this must be simple, but I can't figure it out!!
Usine doesn't seem to have any way to send a series of events of the same value.....
thanks,
-eric
event on button press only
Maybe this?:)
yeah, that looks like it would work.... I'll try it.
Thanks!!!!
Thanks!!!!
Clearscreen
That seems like weird behaviour though - the reset works fine with just a button on to the "<<" here? I can't get it to reset on the release at all? Strange...
Try midi learning on the button. I think it may behave differently then....
