preset manager related question
tanabarbier
Unread post by tanabarbier » 27 Jun 2011, 18:05
when I try to copy paste some elements, for exemple to put them all in a subpatch, the preset manager doesn't work after moving it.
Is it normal ? Is there a workaround ?
Thanks !
Unread post by nay-seven » 27 Jun 2011, 18:15
yes, it's quite normal cause some parameters/path have changed so the manager can't know it easily...?
tanabarbier
Unread post by tanabarbier » 27 Jun 2011, 19:53
Yes that's what I was affraid of. So no way to make preset manager exportable ?
It could be awesome to have the possibility to save and recall preset manager with specific VSTI or else, from a patch to another, or workspace...
Unread post by nay-seven » 27 Jun 2011, 20:07
oh, no problem this way
create a patch with a vst/vsti and some preset manager
save this patch
you can now use this patch where you want
the problem occur if you change in this patch the emplacement of element like faders, knobs and so..
Users browsing this forum: No registered users and 147 guests
