Midi CC mapping control from Cubase >> Usine?
UsineHeaven
Hello and Welcome usineheaven,
I don't see any problem to achieve this, you can even begin to learn in the VST free version, then the poly mode will help you to go further in the pro one.
and remember we are here to help you
UsineHeaven
Thanks for your answer!
Just to be absolute sure, I want to create custom mappings for current VSTi plug-ins.
I want to create interface for again current VSTi plug-ins that I use from different vendors.
I can only test Helion as VST Usine crashes my Cubase as soon I try to open 2x2...
Any idea?
Cheers.
Any idea?
Cheers.
can you give us the Cubase version you use..?
(even if it's not easy to test cause they don't provide demo version easily)
UsineHeaven
Yes, Cubase 6.0.2 at 32 bit on Win 7 64 bit. Powerful PC with plenty RAM.
UsineHeaven
Cubase 6 have its demo version here:nay-seven wrote:can you give us the Cubase version you use..?
http://www.steinberg.net/en/products/cu ... rsion.html
Cheers.
thanks, but to download a demo version, you have to create an account ( ok, done) but also you have to buy an USB-eLicenser 21€...crazy
I'm gone to look for others users to check first
UsineHeaven
OK, yes. I can sponsor such USB-elicenser, just to know if we should chose Usine for project or not. I have a tight dead line so it would be good to know ASAP.
Cheers.
Cheers.
UsineHeaven
Good news. I managed to get it work properly. If opened at the same time as a standalone then it works. Thanks.
Great !
really good news cause this elock solution is not easy !
Users browsing this forum: No registered users and 1163 guests
