Midi CC mapping control from Cubase >> Usine?
UsineHeaven
Unread post by UsineHeaven » 27 Jun 2011, 06:35
I'm wondering 2 thing as I'm interested to buy Pro version.
1) What I want to achieve is to create a custom midi CC mapping for plugins that will execute within Cubase. Will it be possible to do that with Usine??
2) Can I create my own interfaces but use them from Cubase enviromnent?
Cheers.
Unread post by nay-seven » 27 Jun 2011, 08:31
Hello and Welcome usineheaven,
I don't see any problem to achieve this, you can even begin to learn in the VST free version, then the poly mode will help you to go further in the pro one.
and remember we are here to help you
UsineHeaven
Unread post by UsineHeaven » 27 Jun 2011, 09:02
Thanks for your answer!
Just to be absolute sure, I want to create custom mappings for current VSTi plug-ins.
I want to create interface for again current VSTi plug-ins that I use from different vendors.
I can only test Helion as VST Usine crashes my Cubase as soon I try to open 2x2...
Any idea?
Cheers.
Unread post by nay-seven » 27 Jun 2011, 09:25
can you give us the Cubase version you use..?
(even if it's not easy to test cause they don't provide demo version easily)
UsineHeaven
Unread post by UsineHeaven » 27 Jun 2011, 10:04
Yes, Cubase 6.0.2 at 32 bit on Win 7 64 bit. Powerful PC with plenty RAM.
UsineHeaven
Unread post by UsineHeaven » 27 Jun 2011, 16:18
nay-seven wrote:can you give us the Cubase version you use..?
Cubase 6 have its demo version here:
http://www.steinberg.net/en/products/cu ... rsion.html
Cheers.
Unread post by nay-seven » 27 Jun 2011, 18:09
thanks, but to download a demo version, you have to create an account ( ok, done) but also you have to buy an USB-eLicenser 21€...crazy
I'm gone to look for others users to check first
UsineHeaven
Unread post by UsineHeaven » 27 Jun 2011, 18:23
OK, yes. I can sponsor such USB-elicenser, just to know if we should chose Usine for project or not. I have a tight dead line so it would be good to know ASAP.
Cheers.
UsineHeaven
Unread post by UsineHeaven » 28 Jun 2011, 04:15
Good news. I managed to get it work properly. If opened at the same time as a standalone then it works. Thanks.
Unread post by nay-seven » 28 Jun 2011, 07:19
Great !
really good news cause this elock solution is not easy !
Users browsing this forum: No registered users and 474 guests
