Can I do this?
James R
Unread post by James R » 19 May 2011, 23:40
Hello new here,
I have searched around the net for awhile looking for a something that would work like Waves multirack.
Which enables you to use waves plugins in a live sound enviroment, patching eq's compressors etc in a chain within a rack.
Only limited by the amount of processing from the cpu and memory. I have a Motu MKII 8 in 8 out analog that I can use as the interface.
Can I use Usine to host my plugins and interface the in and outs? I hope I got this clear enough.
James R.
tanabarbier
Unread post by tanabarbier » 20 May 2011, 03:55
I think this is really doable, the only thing that you'll have to worry about is the latency, but it can be really low with usine. You could even try with the free version to see how it works with only 2 ins and outs (if I remember well the limitation).
Unread post by nay-seven » 20 May 2011, 07:52
welcome James
yep, the rack mode is what you're looking for.
James R
Unread post by James R » 20 May 2011, 12:02
Nice, Thanks for the replies. Will give it a try
James R
James R
Unread post by James R » 20 May 2011, 12:57
I had another thought, after browsing the forum some more. Do think Usine could interface with a DMX lighting program like Mydmx?
James R
Unread post by nay-seven » 20 May 2011, 13:28
don't know about this software ( if he can receive OSC message or midi , it's ok )
but there is also a dmx module
check EnttecProDMX and Utils lights in the addons
Users browsing this forum: No registered users and 364 guests
