a request for script gurus
was wondering if it's possible to have a generic script for the matrix module
i imagine some listbox inlets for example named
switches
button
switch group 1
switch group2..
where you enter a list of number to specify the cells function
this way we can say cells 10,11,12,13,14 are a group of switches
cells 15 & 16 are buttons and so...
do you think it's possible..?
switches
button
switch group 1
switch group2..
here an example to illustrate :
here a matrix recorder where the last row have different functions
some like rec, over,pause must be switches , clear have to be a button, and last 1,2,3,,4..are different pattern so must be a group of switches..
mm seems doable i can try to have a look.
i wonder if a system to configure directly via a menu wouldn't be more easy for user.
ie we enable a 'configure' swich. then we choose button and clic all the cells that must be a button, then leave configure.
then do same for swiches and group swich. i just wonder how to deal multiples group. but i will try with only one group first..
cool, and yeah, the listbox is just an idea
Code: Select all
// MX_MULTIMODES_ 23fx15/05/2K11
// allow to configure cells to act as
// momentary/toggle swich or group swiches
// parameters declaration
var Config,MXsize:tparameter;
var Ctype:tparameter;
var arrayout,MEMtypes:tparameter;
var IDclic:tparameter;
var Msdwn:tparameter;
var L, cty,ID: integer;
var msd,cfg:boolean;
procedure init;
begin
MXsize:=createParam('Mxsize',ptdatafield);
setisoutput(Mxsize,false);
Config:=createParam('config',ptswitch);
setisoutput(config,false);
ctype:=createParam('ctype',ptListBox);
SetListBoxString(ctype,'button,swich,G1,G2,G3,G4,G5,G6,G7,G8');
setisoutput(ctype,false);
idclic:=createParam('idclic',ptdatafield);
setisoutput(idclic,false);
msdwn:=createParam('msdwn',ptdatafield);
setisoutput(msdwn,false);
arrayout:=createParam('arrayout',Ptarray);
setisinput(Arrayout,false);
MemTypes:=createParam('Memtypes',Ptarray);
setisinput(Memtypes,false);setdontsave(memtypes,false);
msd:=false;
cfg:=false;
end;
// Callback procedure
begin
if (n=mxsize) then resize;
if (n=config) then begin
cfg:=getvalue(config)=1;
end;
if (n=idclic) then begin
if getvalue(idclic)>-1 then begin
ID:= trunc(getvalue(idclic));
end;
end;
if (n=msdwn) then begin
MSD:=getvalue(msdwn)=1;
if MSD then begin
//resize;
if CFG then begin
setdataarrayvalue(memtypes,ID,getvalue(ctype));
end;
cty:= trunc(getdataarrayvalue(memtypes,ID));
itrace(cty);
end;//msd
U_CELLS(cty);
end;//msdwn
end;
Procedure U_CELLS(mode : integer);
var i:integer;
begin
if mode=0 then begin //button,mmt mode
setdataarrayvalue(arrayout,ID,getvalue(msdwn));
end;
if (mode=1) and (MSD) then begin
setdataarrayvalue(arrayout,ID,1-getdataarrayvalue(arrayout,ID));
end;
if mode>=2 then begin
for i:=0 to L-1 do begin
if getdataarrayvalue(memtypes,i)=mode then begin
setdataarrayvalue(arrayout,i,0);
end;
end;
setdataarrayvalue(arrayout,id,1);
end;
end;
Procedure RESIZE;
begin
L:=trunc(getvalue(Mxsize));
setlength(arrayout,L);
setlength(memtypes,L);
end;
//////////////////////////MultiModes_MX
when you enable configure, you can choose a type in combobox (button,switch, or one of 8 group)
then clic the cells you want to behave like this. once done swich of configure.
edit: i forgot, you can delet the line itrace(cty); and make reload script.
the cells type should normally be memorized and you can use preset manager to recall to different layouts.
whaoo! so fast crazy boy !
works perfectly , now i've some incompatibility with my visual feedback mode but maybe there's some workaround
will let you know
And i thinks this could be a cool script for many uses and to quickly build patches
Many Thanks !!!
will let you know
Many Thanks !!!
cool, yup it will be helpful for me too
. btween it's not the ultimate optimized code for very big matrix, but was much easier
to code like this than tracking and incrementing size of groups, and cpu seems fairly descent like this so...ive chosen the lasy way
let me know if you got pbs with your feedback mode, maybe you need some arrayin to feed the script or i don't know?
(if so you can try to deploy the script so that array out pin is visible on input, and feed your stuff maybe..
happy it's helpuf for ya nay'
hey nice job i love this patch ! Well done 23fx23.
me again,
seems that the state of the cells are not memorized by a preset manager...?
mm oh yup, forgot that. try this one:
or if you already made assign and don't wanna loose them, add the line in init after arrayout creation:
setdontsave(arrayout,false); then make 'reload script'
Code: Select all
procedure init;
begin
setisinput(Arrayout,false);setdontsave(arrayout,false);
msd:=false;
cfg:=false;
end;
begin
end;
end;
end;
if MSD then begin
//resize;
if CFG then begin
end;
end;//msd
U_CELLS(cty);
end;//msdwn
end;
var i:integer;
begin
end;
end;
end;
end;
end;
end;
Procedure RESIZE;
begin
end;
//////////////////////////setdontsave(arrayout,false); then make 'reload script'
great !
works fine
thanks again
works fine
thanks again
Cool one, but i have a special request:
I really need a slave one for my novation launchpad patch,
please, could you take a few minutes to add a "memtypes" array input?
That would be great, thanks in advance.
Edit: forget it,
was really easy and simple to patch.
Edit: forget it,
