math problem
Hi
Nobody on the french forum to help to resolve my problem ?
I'll try to explain it here.
I'd like to convert pitch data in time data.
i can modify the pitch with positive negative or 0 values (0 mean no pitch so 100% of the duration of my sample)
I'd like to deduce the operator which permit me to calculate the duration of my sample when i modify the speed.
thank you.
Jof
thank you.
Jof
sorry, was dreaming during maths lessons..
any maths guru for joffo..?
mmm speed double and length reduce of half when pitched an octave (+12),
so if not wrong should be len= original len / (pitch/6) maybe.
I was sure I had brought up this issue once, so I did a search and found this thread from 2006. You'll find the formula there.
ok thank you
this formul : original_length / 2^(pitch/12) = shifted_length
seems interest me but i don't know what the symbol ^ means...
and how can i apply this formule in usine ?
^=power.
It's in the maths section of the browser as A ^ B (power)
So i tried to traduct this : 300 / 2^(7/12) = 200.225978126 in usine language without success
may i did some mistake ?
here it is : ( when there's parenthesis...)
@bsork: you're the Usine's encyclopedia!
So Nay you're not so bad in math.No more than me !
Users browsing this forum: Google [Bot] and 16 guests
