Aux routing issue in Usine VST
bewithmot
Unread post by bewithmot » 05 Apr 2011, 07:29
Here's what I've done :
Make an audio track in Cubase5(or Reaper, I tested both and same result) and import any simple audio file into the track.
Add Usine VST as an insert.
Make another empty audio track and insert another Usine instance. (Actually it's same instance internally, am I right?)
Now open up the Usine GUI window.
Set track2 input to 'aux 1' and send track1 output to 'aux 1'.
Playing this setup should make a single louder sound of the imported clip, but somehow it sounds like slap-back delay.
There's mysterious delay between aux send and receive, and it's not just a few ms but 100ms or something.
Changing ASIO buffer size or Usine VST setup doesn't affect this at all.
What am I doing wrong?
Very same aux routing works just fine in standalone version.
I'm using Cubase5 32bit(or Reaper 64bit), and Fireface 400. OS is Win7 64bit.
(Pardon my poor english. :))
i5 CPU, 8 GB ram, Windows 7 64bit, RME Fireface400,
Cubase5 32bit, Reaper 64bit, Max 5, Bidule
Unread post by nay-seven » 05 Apr 2011, 09:27
mm, just test in Reaper 32 with last usine vst pro version, can't reproduce this..
can someone else test..?
bewithmot
Unread post by bewithmot » 05 Apr 2011, 16:45
While hoping someone comes up with a solution,
I was trying Easine vst and I just found out Easine vst is not working either. :(
It's like ... all DSP is off. No cpu load, no processed audio.
And it has no VST buffer size setting, which seems kinda weird to me because Usine VST has one. Is it normal?
No problem with IB and patching, though.
I hope this symptom could be a clue to figure out what's wrong with my system. :(
Unread post by nay-seven » 05 Apr 2011, 17:51
really don't know what's happen with your system, easine vst ( last version 5.50.55 ) is working here , i 've just try on a reaper 64bits version...
Users browsing this forum: Bing [Bot] and 201 guests
