Hi
i meet some trouble when i try to work with osc (only with one of my 2 computers).
usine display "error:Send failed: socket permission denied"
and i can't send osc informations in another software. Usine and the other are correctly configurated because when i do the same on another computer it works...
error message when i work with osc
martignasse
seems like the firewall is blocking the socket creation.joffo78 wrote:usine display "error:Send failed: socket permission denied"
check if the port used by usine for OSC is in the exception list of the firewall, create it if needed
hop it help
hello martignasse thank you for you advice but i tried to turn off my firewall and it doesn't work more.
it's a good thing to meet you because i had a lot of suggestions for your amazing matrix module !
it would be fantastic if we could take an individual value on each cell by numeric value (for example cell n°25 at 0.5)
it would be great to if you could display each number of cell then a value corresponding of the cell content (cell 1/0.78 cell 2/1 cell 3/0.52 etc).
i'd like to change the value of only one of the cell without changing the other (at the array input make a script for selecting cell then value).
i hope we could understand me.
and for the osc i can't manage to resolve my trouble.
thanks
JF
thanks
JF
My problem of osc is solved i'll try to elaborate a patch witch sequences sounds,lights and videos
i hope i will can manipulate values in the matrix as i asked you.
thank you
thank you
martignasse
cool, now you can begin the hard work
what was the problem and how you solved it ?
PS : for your questions about the matrix, i transfered them in the appropriate thread, here
just to know, and to help other.My problem of osc is solved
Yeah i had a problem in resolume when i opened it before usine. Curiously my firewall didn't detect the osc of resolume.
Users browsing this forum: No registered users and 45 guests
