I am trying to get the path to the current patch using GetUsinePatchPath() but it doesn't seem to be returning anything. Calling the following code just prints a blank line to the console. Am I having a bad day and made an obvious mistake or does this function not work correctly?
[c]pPrototype->TracePChar(pPrototype->GetUsinePatchPath());[/c]
Tried in both SDK 5.1 and 5.25. Thanks for the help!
How to get patch path?
martignasse
Hi caco,
i'll check that today and report.
thanks for the feedback
martignasse
confirmed
in fact, all these functions :
return bad/corrupted data
i'll have to see that with senso
Code: Select all
GetUsineSoudPath()
GetUsinePatchPath()
GetUsineVst1Path()
GetUsineVst2Path()
GetUsineRecordPath()i'll have to see that with senso
- senso
this bug will be solved in the next version 5.50.49 and above.
