Recalling directly a line
Unread post by grego mondo » 03 Mar 2011, 21:44
I found next and previous line but I'd like a "go to line umber x" so when I make visible a patch i IB I'm shure it's selected and midi learns will work.
hope I'm clear ... thanks
Unread post by nay-seven » 03 Mar 2011, 22:27
waiting for an improvement, here a workaround
create this patch and send this as midi learn to the user curves combobox...? use midi canal 16 or any one you don't use yet
Unread post by senso » 04 Mar 2011, 22:32
yes i'll try to find something.
Unread post by grego mondo » 05 Mar 2011, 12:11
@ Nay
thanks, it should work better than what I did :
check the number of the line (eg 5) and decrease line until wanted line is reached (eg 3).
And obviously there are tricks to do whatever we want to ... but sometimes, you realise that you're not alone in your wish ...
