receive midi clock
gurulogic
Unread post by gurulogic » 25 Feb 2011, 05:03
I must be doing something wrong. I cannot get the receive midi clock patch included with the latest Usine to work.
I have connected all 5 midi "in" to my midi input and turned the patch on but no go. If I use the older version of the receive midi clock patch it works.
Am I missing something?
Floego
Unread post by Floego » 25 Feb 2011, 05:56
what about the console? can you see some midi activity on it?
gurulogic
Unread post by gurulogic » 25 Feb 2011, 07:15
yes the console has activity. and like I say if I use the older receive midi clock patch,in the same patch, sync is received. it seems like a problem with the patch but I would imagine someone else would have noticed.
gurulogic
Unread post by gurulogic » 28 Jun 2011, 19:42
Ok, some months later and I am trying this again. All the the receive midi clock patch does for me is set the Usine tempo to 30bpm and control start and stop. I cannot remotely set tempo. Help?
Unread post by senso » 29 Jun 2011, 08:38
maybe the "ignore time clock" in the setup is activated?
gurulogic
Unread post by gurulogic » 29 Jun 2011, 10:05
senso wrote:maybe the "ignore time clock" in the setup is activated?
No, it is not.
Ok, I'm a little rusty right now but if I am correct I should be able to load the Receive MIDI Clock sub patch into a patch and connect the midi out from the midi input module to all of the midi inputs to the patch and fully control Usine via remote transport and remote tempo, correct? All I am getting is remote transport.. and this is definately not a problem of my external gear not sending clock. Everything else is working fine from the same clock, but I can't help but think I am doing something wrong if no one else has this problem..?
gurulogic
Unread post by gurulogic » 29 Jun 2011, 19:25
Ok, figured it out. Unlike previous Receive Midi Clock patches, this patch must be the top parent patch.
Users browsing this forum: No registered users and 140 guests
