problems with UAC in Win7x64
Document02
Unread post by Document02 » 16 Jan 2011, 17:55
Each time I start usine, I get a UAC request for the software. This should normally only happen during installation (or when doing some files association routines) but I get this every time I run Usine.
Does anyone have a clue on how to get rid of this ?
Unread post by nay-seven » 16 Jan 2011, 18:30
my first answer would be : do you really need UAC..?
then, generally,as you said, it's happen only one time ( Usine don't have installation,, it's a portable software )
runagate
Unread post by runagate » 16 Jan 2011, 18:30
Try this: right click the .exe and click properties and then the "compatibility" tab, then the button that says "change settings for all users" at the bottom, and then click "run this program as an administrator" under Privelege Level.
Document02
Unread post by Document02 » 16 Jan 2011, 19:33
@rungate: didn"t work. Thanks anyways.
Actually I found a workaround, but am not sure it is good practice: directly launch UsineFileUsineMain.exe .
Unread post by 23fx23 » 16 Jan 2011, 21:10
i think you can safely directly run usineMain.exe. i do this as well
Document02
Unread post by Document02 » 16 Jan 2011, 21:24
Thanks 23fx23
Users browsing this forum: Google [Bot] and 14 guests
