half tones
héliouk 6
Unread post by héliouk 6 » 13 Jan 2011, 09:34
i wonder if it's possible to make the pitch of a sampler run without earing the half tones passing but a flow from one tone to another ,as theremin or scie musicale? a way to do that or implement something?
headphoner
Unread post by headphoner » 13 Jan 2011, 09:47
Hi heliouk,
did you try the smoother module?
Unread post by nay-seven » 13 Jan 2011, 09:48
yep, the smoother module between your pitch knob and the pitch inlet of a grain sampler ( to have better result ) must work..
héliouk 6
Unread post by héliouk 6 » 13 Jan 2011, 13:43
i think i tried but not with the grain sampleur,i'm gonna try that. thanks guys.
Unread post by senso » 14 Jan 2011, 09:12
the sampler module is absolutely not tempered !
by default pitch values are rounded but if you connect a fader with a x.xx precision to the pitch inlet, the pitch will be have the same precision.
You can have a 12.45 pitch if you want!
