record trajectory
joffo78
Unread post by joffo78 » 21 Dec 2010, 00:06
Hi i noticed that it was impossible to record in the conductor or in a preset manager the trajectory.
it would be cool if we could do that :)
Unread post by nay-seven » 21 Dec 2010, 09:29
if you add a ramp module ( his array out to the index inlet of the trajectory module ) your drawing will be saved
( check for example my addon 4layers )
joffo78
Unread post by joffo78 » 21 Dec 2010, 20:03
Sorry but even with your patch my drawing is not saved in the conductor (it dosen't change when i recall another preset or scene) please check it ...
Unread post by nay-seven » 21 Dec 2010, 20:29
this don't work if you use only the conductor
you need a preset manager in your patch , and set it to "recall by conductor"
i admit you have to save in your preset manager and in the conductor...
but works this way
joffo78
Unread post by joffo78 » 21 Dec 2010, 20:40
ok i will try it sudently
