Presets and Allow drop !
Ken29
Unread post by Ken29 » 20 Dec 2010, 17:11
Here's a simple patch that doesn't work the way I expect.
I'd simply like to drop a file, then save a preset and find it back in text box when I recall the preset but the "drop file name" output doesn't seems do be memorized by the preset and always send the last drop to the text input. Any idea to make it work !
Thank Kenan
Unread post by 23fx23 » 20 Dec 2010, 18:23
hi ken29, try by adding 'a pass if change' on the text wire before it goes back to the text input.
Unread post by 23fx23 » 20 Dec 2010, 18:35
sorry, i just tested and that doesn't work. in fact the txt module doesn't save presets,
but the TxtField module does. so here is a working way:
Unread post by nay-seven » 20 Dec 2010, 19:42
cool workaround 23fx !
Ken29
Unread post by Ken29 » 20 Dec 2010, 22:35
it works perfectly as expected !
Kenan
Users browsing this forum: Bing [Bot] and 22 guests
