ustring: monophonic plucked string synth
soundmind
Unread post by soundmind » 24 Nov 2010, 16:19
"ustring is a monophonic plucked string synthesizer based on the Karplus-Strong algorithm. It works by taking a short excitation burst (pluck) and feeding it into a delay whose length is equivelent to the frequency of the currently played note."
Unread post by nay-seven » 24 Nov 2010, 17:56
well done !
no need to sleep those days..?
and one UsineAddict more...:D
ethnix73
Unread post by ethnix73 » 24 Nov 2010, 18:48
Nice one!
I had a try and never finished the patch...
P.S: You will soon need a cure.
Seb.Dub
Unread post by 23fx23 » 24 Nov 2010, 19:29
yeah there is a high production rate of hi qualiry stuff here;)
soundmind
Unread post by soundmind » 24 Nov 2010, 22:33
thanks for the comments. My next goal is to make a polyphonic version. I'm still brainstorming ideas...
Unread post by senso » 25 Nov 2010, 04:22
well done soundmind,
for info:
the next major release will be polyphonic, so your goal will be achieved very easily!
soundmind
Unread post by soundmind » 25 Nov 2010, 08:39
nay-seven wrote:no need to sleep those days..?
This concept of sleep that you speak of sounds vaguely familiar. can it be done in a patch? :cool:
senso wrote:the next major release will be polyphonic, so your goal will be achieved very easily!
This sounds great! thanks for the info.
waolelaid
Unread post by waolelaid » 26 Nov 2010, 20:01
Hi soudmind i'm alittle bit lost how to install don't know where to put
the wave files
thanx :)
Friedrich Nietzsche
soundmind
Unread post by soundmind » 26 Nov 2010, 20:49
just unzip the file and open the wkp. everything should work because I exported the workspace so the sampler should look for the files in the "audio" folder?
Users browsing this forum: No registered users and 102 guests
