Step seq launchpad preview
ethnix73
Unread post by ethnix73 » 09 Oct 2010, 02:09
Here is a little preview of a simple step sequencer with a launchpad as a remote midi controller.
There are still a few minor bugs in this video, but they are easy to solve. Normally adding others others steps fir longer sequence will be included inthis patch. Others improvements like choosing pad color in the launchpad will be also included.
The "midi to matrix" is a little more cpu intensive than expected because i did not find a betterway to deal with the incompatibility between the matrix exclusive mode and the preset manager
The main difficullty was to find a good way to make a video with a medium quality.
My goal is just to show Usiners the progress of patches for the launchpad and Usine; and the possibilities between them. Further different patches will folow. i will upload a better video when this patch will be finalize....
Suggestions and Ideas are, of course, welcome.
http://www.youtube.com/watch?v=52swAM3pNoQ
Seb.Dub
Unread post by 23fx23 » 09 Oct 2010, 02:43
yeah cool!!. I like the way you tab and cols controls stuff like velocity and lenght. well done!
little sugg : maybe full control from lauchpad ie of the tabs, but i suppose it's planned.
and maybe a pointer or row running to show loop position on launchpad?
good job!
Unread post by nay-seven » 09 Oct 2010, 09:00
great !
well done Ethnix !
and yep, as say 23fx , could be cool to use , for example the low row to choose velocity tab and so..
Unread post by senso » 09 Oct 2010, 10:21
whaaooo!!!!
ethnix73
Unread post by ethnix73 » 09 Oct 2010, 10:44
@23fx23 and nay-seven:
Yes, all function will be accessible from the launchpad. Concerning velocity, octave and lenght tab, i had done it in a previous versions, and it's easy to do. It is not included in this one because i wanted before to implement the preset manager with an exclusive mode matrix....
Back to patching :)
Seb.Dub
Unread post by senso » 09 Oct 2010, 11:17
as 23fx sugg:
instead of a list to choose note/octave/length/etc may be you could create grouped switch?
then we could easily make midi-learns on them?
ethnix73
Unread post by ethnix73 » 09 Oct 2010, 11:30
@senso:
yes of course, this list box is still here because it was more convenient for patching.
I had already done the patch with grouped switch, but as this version had nasty bugs, i had to redo it from scratch...
Seb.Dub
ethnix73
Unread post by ethnix73 » 27 Oct 2010, 12:01
here is another video preview of this patch
Click here
Seb.Dub
Unread post by nay-seven » 27 Oct 2010, 12:29
well done ethnix!
more and more powerful !
by curiosity , how many matrix module do you use..?
ethnix73
Unread post by ethnix73 » 27 Oct 2010, 13:18
Only one matrix because i stock the different values in arrays before the matrix.
It's the lighter on cpu solution i've found , to deal with the incompatibility between exclu mode and preset manager.
The patch uses 2.5% on an old athlon 3500+ and an ugly onboard soundcard with asio4all
Seb.Dub
Unread post by nay-seven » 27 Oct 2010, 15:02
yes, i also use this method ( but in reverse i stock values after the matrix cause i use it directly to enter notes ), it's why i ask .
and what about animation of the sequence , could give life to your patch ..? ( don't hesitate to check the sequenaya method martin give me with the col border selector)
ethnix73
Unread post by ethnix73 » 27 Oct 2010, 17:53
Yes, i will animate the patch and the launchpad. As it is quite easy to implement it, i will put it at last...
How do you enter directly notes in the matrix?
By converting index or by caption?
Seb.Dub
Unread post by nay-seven » 27 Oct 2010, 21:55
yes, converting the index ( but i don' invent the wheel , most was done by martin..)
ethnix73
Unread post by ethnix73 » 28 Oct 2010, 21:52
Finally, i've done it this evening
Seb.Dub
Unread post by 23fx23 » 28 Oct 2010, 22:40
yeaaaah it's alive! well done ethnix
ethnix73
Unread post by ethnix73 » 09 Nov 2010, 11:47
Two little video with new functions:
Poor playing sorry :)
video 003
video 004
Seb.Dub
ethnix73
Unread post by ethnix73 » 12 Nov 2010, 16:58
To come:
-Swing fonction
-Possibility to bypass some steps in the sequence
Playing with this two functions, autochord mode and alternate mode, you can achieve some interesting feelings...
Seb.Dub
borgmekanik
Unread post by borgmekanik » 19 Dec 2010, 10:28
this looks very cool. Is is available for download somewhere ?
Do i need the pro version for this ?
Unread post by 23fx23 » 19 Dec 2010, 10:41
that's trippy those little lights and nice sound , the new functions seems cool, when u play live it creates really nice melodies.
:cool:
Unread post by nay-seven » 19 Dec 2010, 10:50
hello borgmekanik and welcome
Ethnix 73 is the author of this patch so he'll answer better than me but i know he's working on different version of this patch and it will be available soon i suppose ..
ethnix73
Unread post by ethnix73 » 19 Dec 2010, 19:09
You can't yet download this addon...It will be available when Usine 5.50 will be out.
I will upoad it on the addons sections, so yes you will need the pro version to download it...
I need to work a little more on this patch because since a few weeks i'm working on an mlr/molar like patch.
Thanks for your kind words 23fx23
Seb.Dub
artificial
Unread post by artificial » 18 Nov 2011, 23:28
hi! is this addon already available? because, I'm also creating something with my launchpad, but still have some issues with midi messages and the leds... so I really would love to learn from your patch! ;)
thanks in advance!
Users browsing this forum: Bing [Bot], Google [Bot] and 591 guests
