How relocate Samples in sample's module
Simonaki
Unread post by Simonaki » 07 Nov 2010, 17:50
Hi extra Usiners
I've got a question about relocating sample,
i've change the place of my samples and open my old patch, but impossible to relocate them....
it works for exemple in Phatmatik (Izotope) an ask to relocate and it works
But not in sampler or granular module...
Any suggestion friends ????
Best
Unread post by senso » 07 Nov 2010, 21:00
why this function is not implemented yet?
I have doubts about the efficiency of such a solution and each time I've tried to implement it I had many troubles, which make it unusable:
- on a "normal" audio Hard Disk we can have giga's of files and it can take few minutes for each sample for an automatic location.
- what happen if we use the same name for different files?
Finally, from my my own opinion, it's faster and more safe to recreate the list manually?
Simonaki
Unread post by Simonaki » 07 Nov 2010, 22:29
I Senso
It's not faster for me...
I ve got lot of small sample...
And i rename in different name all sample...
I resign to search new samples...and never move again the folder's name....
Why Not ! ! !
Simonaki
Unread post by Simonaki » 09 Nov 2010, 01:17
I Usiners
Is it possible to resize the sample list windows?
It happens that the window is too small and I can't see the full name and the tree samples...
do you have this problem?
BEst
ethnix73
Unread post by ethnix73 » 09 Nov 2010, 01:57
Do you use a combo box?
Seb.Dub
Unread post by senso » 09 Nov 2010, 09:15
Actually impossible, I'll see if I can do something.
Unread post by cmodica » 09 Nov 2010, 09:35
I think the best way when there is a lot of sample in the list is to export your workspace in a new directory. So all your sound, patches ... will be in the same place.
Perhaps you can try to save your sample list and change it manually with a text editor ? I never try. But of course you had to know where are they ...
