[large]Usine 5.25j[/large]
This version fixes several important memory crashes in some modules on recall preset operation.
[large]fixed bugs[/large]
- [usine] bad initialization of the HID device module
- [usine] The inlet color of the knob module doesn't work
- [usine] memory crash in the Audio Mixer on recall preset
[large]notes[/large]
On previous 5.25 installation you can only replace the UsineMain.exe file.
Usine 5.25j update
thanks!
btw, I like the new way for dowloading the zip file.
it's a 'LeVraiBernardo' idea. Great job!
thanks & good way of downloading +2
A bit strange, I have to right click and 'download as' from the link in my gmail. If I just click the link I get the internet explorer file download security notification but after I choose to download the file, nothing happens. Maybe this is just a problem with my own computer?
gurulogic: try this:
switch gmail to the 'basic html display' and try the download link again.
hope this help
hope this help
Users browsing this forum: No registered users and 131 guests
