Usine vst question - load only piano roll?
Ok, I am onboard having just bought a Pro License!
Can I just load the Usine Piano roll when uisng the vst version? I am using Cantabile as my host; The one thing I have been wanting for Cantabile is just a piano roll.
Using Usine as a vst, I have learned how to add the paino roll module and then setup the midi out so it does work. But I am a bit curious, since I have to go through a few steps is there any way to only get the piano roll to open instead of going through the Usine main screen?
Regards, James
Regards, James
I also would like this for screen focus and open only ability for some of the midi add-ons like "smartusines", "rhombusine", etc ... Kinda like they were vst's that I was opening inside my host with just a click of one button.
Regards, James
Regards, James
no, sorry
the piano roll is a module of Usine so you have to run Usine to use it..
but welcome in the gold members world...
and of course same answers for addons...but who knows ..maybe one day
Something like this?
edit: I'm half asleep, there's a better way. Assuming this is what you were trying to do?
Thanks for the answer. Btw, where are the demo workspaces located?
Regards, James
Regards, James
you mean : Usine pro standalone 5.25xx/files/demo...?
Ok - I am gald there are sample projects to learn from. It seems in the Usine browser I do not see the demo files to load thus my question; In windows explorer as you mentioned in the Demo folder I see lots of I see there are lots of .pat projects to workthrough.nay-seven wrote:you mean : Usine pro standalone 5.25xx/files/demo...?
Regards, James
I plan to print out the manual and the quick start manual this week, but thanks for the help as I am now listening to the demos
just a tip : gurulogic give me the idea , :
in cantabile next the piano , on the left you have 4 button , right click on one and choose customize / choose the midi controller number you want
in Usine add a switch to the visible inlet of the piano roll
right click on it choose remote mode toggle and then midi learn it with the cantabile button..et hop
you have a button in cantabile who open the piano roll...
update : you have to minimize the Usine window, this way Usine don't open over cantabile when you click again on your cantabile button to hide the piano roll...
in, fact when you'll be more easy with Usine you'll see that you can do the same with addons, putting them in container and link the switch to their visible inlet..
can't seem to get to "right click on it choose remote mode toggle" so I attached a picture where I got stuck at
no , my fault :you have to right clik on the switch but on the control panel :
LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more fun
However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Also I am starting to consider the possibility that of a Usine add-on like http://matrixsynth.blogspot.com/2010/06 ... -midi.html would really make my setup fun.
Regards, James
Regards, James
Welcome aboard James, cool link it reminds me of a software Synderphonics Mantasunhome wrote:LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more funHowever the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Regards, James
actually, the developers website has more info on ijammer [ in comparison to my earlier url posted ]
http://www.tradlessons.com/iJammer.html
Users browsing this forum: No registered users and 1018 guests
