Usine vst question - load only piano roll?
sunhome
Unread post by sunhome » 20 Oct 2010, 18:19
Ok, I am onboard having just bought a Pro License!
Can I just load the Usine Piano roll when uisng the vst version? I am using Cantabile as my host; The one thing I have been wanting for Cantabile is just a piano roll.
Using Usine as a vst, I have learned how to add the paino roll module and then setup the midi out so it does work. But I am a bit curious, since I have to go through a few steps is there any way to only get the piano roll to open instead of going through the Usine main screen?
Regards, James
sunhome
Unread post by sunhome » 20 Oct 2010, 18:22
I also would like this for screen focus and open only ability for some of the midi add-ons like "smartusines", "rhombusine", etc ... Kinda like they were vst's that I was opening inside my host with just a click of one button.
Regards, James
Unread post by nay-seven » 20 Oct 2010, 18:26
no, sorry
the piano roll is a module of Usine so you have to run Usine to use it..
but welcome in the gold members world...:)
Unread post by nay-seven » 20 Oct 2010, 18:28
and of course same answers for addons...but who knows ..maybe one day
gurulogic
Unread post by gurulogic » 20 Oct 2010, 18:28
Something like this? Image
edit: I'm half asleep, there's a better way. Assuming this is what you were trying to do?
sunhome
Unread post by sunhome » 20 Oct 2010, 18:38
Thanks for the answer. Btw, where are the demo workspaces located?
Regards, James
Unread post by nay-seven » 20 Oct 2010, 18:43
you mean : Usine pro standalone 5.25xx/files/demo...?
sunhome
Unread post by sunhome » 20 Oct 2010, 18:55
nay-seven wrote:you mean : Usine pro standalone 5.25xx/files/demo...?
Ok - I am gald there are sample projects to learn from. It seems in the Usine browser I do not see the demo files to load thus my question; In windows explorer as you mentioned in the Demo folder I see lots of I see there are lots of .pat projects to workthrough.
Regards, James
sunhome
Unread post by sunhome » 20 Oct 2010, 18:57
I plan to print out the manual and the quick start manual this week, but thanks for the help as I am now listening to the demos :)
Unread post by nay-seven » 20 Oct 2010, 19:08
just a tip : gurulogic give me the idea , :
in cantabile next the piano , on the left you have 4 button , right click on one and choose customize / choose the midi controller number you want
in Usine add a switch to the visible inlet of the piano roll
right click on it choose remote mode toggle and then midi learn it with the cantabile button..et hop
you have a button in cantabile who open the piano roll...
Unread post by nay-seven » 20 Oct 2010, 19:15
update : you have to minimize the Usine window, this way Usine don't open over cantabile when you click again on your cantabile button to hide the piano roll...
Unread post by nay-seven » 20 Oct 2010, 19:45
in, fact when you'll be more easy with Usine you'll see that you can do the same with addons, putting them in container and link the switch to their visible inlet..
sunhome
Unread post by sunhome » 20 Oct 2010, 19:53
can't seem to get to "right click on it choose remote mode toggle" so I attached a picture where I got stuck at
Unread post by nay-seven » 20 Oct 2010, 20:03
no , my fault :you have to right clik on the switch but on the control panel :
sunhome
Unread post by sunhome » 20 Oct 2010, 20:07
LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more fun :) However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Also I am starting to consider the possibility that of a Usine add-on like http://matrixsynth.blogspot.com/2010/06 ... -midi.html would really make my setup fun.
Regards, James
caco
Unread post by caco » 20 Oct 2010, 20:49
sunhome wrote:LOL, I probably won't use the piano roll as much as the add on sequencers ... as the add ons look like more fun :) However the answer for the piano roll would be the same for the add-ons, so again thanks for the help.
Regards, James
Welcome aboard James, cool link it reminds me of a software Synderphonics Manta :)
sunhome
Unread post by sunhome » 20 Oct 2010, 21:42
actually, the developers website has more info on ijammer [ in comparison to my earlier url posted ]
http://www.tradlessons.com/iJammer.html
Users browsing this forum: Google [Bot] and 12 guests
