Changing the time signature with a preset
noise2sine
Unread post by noise2sine » 17 Oct 2010, 23:22
Hello !
Which are the best module I should i use in order to create a patch for recalling by a preset different time signature : for example moving to 4/4 to 21/8 ?
And at the same time different tempo values ?
Thank you !
Unread post by 23fx23 » 18 Oct 2010, 01:02
hi little mouse . for that you can use the master sync module located in /sychro_and_time.
, pick some faders out of it , it ie tempo, cycle length ect.
then add a preset manager, make your settings , store a preset, change settings, store new preset ect...
noise2sine
Unread post by noise2sine » 18 Oct 2010, 10:41
Great thanks !
But i couldn't move to 21/8 it stays only in 21/4 ??
Unread post by bsork » 18 Oct 2010, 11:07
Usine only has 4 as the nominator, so you would have to also double the tempo to simulate the use of 8ths.
noise2sine
Unread post by noise2sine » 18 Oct 2010, 11:21
Is there any chance of having 8 or 2 or 16 as the nominator ??
