trying to make a matrix working like rackmode
manecante
Unread post by manecante » 17 Oct 2010, 19:07
hello,
i am having issues trying to make a matrix working like rackmode. Basically i would like to be able to route each cell corresponding to a FX to another. I started with a simple 2x2 matrix changing the matrix mixer example. But with this example you can only route one time one cell to another (corresponding to the mode all in grid mode) and i would like to do something like the rack mode,
For example route the sound coming in to FX1, then from FX1 route to FX3, from FX3 route to FX2 and so on. So in my patch, the Column x and the Row x are corresponding to the same FX.I am aware it could create some trouble with feedback but avoing to route the colum and row having the same number, it should be possible, no?
I uploaded the patch (matrix_ROUTER_BUGGY2x2.pat) if somebody is up to have a look, that would be great!
http://www.sensomusic.com/forums/upload ... GGY2x2.pat
Unread post by nay-seven » 17 Oct 2010, 19:38
strange use of buses..?
manecante
Unread post by manecante » 17 Oct 2010, 20:12
oups, yes... And there was two bad cable connections as well, but still not working. The audio in in patch level is working but the audio in of subpatch does not get the sound although it is directly connected.
Unread post by nay-seven » 18 Oct 2010, 11:05
ok, so i've try an other way, don't know if it's ok for you
i've used the matrix to open the layout of each effect ( first row blue )
second row is to adjust each effect volume for the audio in
third row is to adjust effect 2 re-inject in effect 1 ( but dangerous , i've limit but not sure it's enough)
download here
manecante
Unread post by manecante » 18 Oct 2010, 21:51
thanks for your patch but it was a bit buggy..but i found my mistake and i did it :)
here it is!
http://www.sensomusic.com/forums/upload ... hainFX.pat
Users browsing this forum: No registered users and 131 guests
