crosstrack patching?
soundmind
Unread post by soundmind » 11 Oct 2010, 09:14
is it somehow possible to patch a wire across tracks without using a bus?
Unread post by nay-seven » 11 Oct 2010, 09:23
can you be more precise..? i mean what kind of data do you want send and why you don't want to use buses..?
Unread post by senso » 11 Oct 2010, 09:35
No It's impossible.
Unread post by bsork » 11 Oct 2010, 10:17
...but you can send audio either through the auxes or directly from one track to another. You can also send internal MIDI messages.
Unread post by senso » 11 Oct 2010, 18:13
If you're looking for a very low latency transfer with buses, disable the multi-cpu option in the setup.
In mono CPU mode there is no latency if you send data from track N to Track M if M>N. Otherwise the latency is 1 Bloc.
soundmind
Unread post by soundmind » 11 Oct 2010, 20:30
senso wrote:If you're looking for a very low latency transfer with buses, disable the multi-cpu option in the setup.
this works perfectly. thanks a lot for the info.
