Usine 5.25
Announcements
Unread post by senso » 15 Sep 2010, 21:58
[large]Usine 5.25[/large]
Probably the most important update since the v5. It contains many important improvements.
The beta test phase is now finished. All reported bugs are fixed.
[large]improvements[/large]
- Aiff sound files compatible
- Zero crossing is active now in the sampler during the recording process, if the option is activated.
- better audio quality and synchro in the Grain Generator module
- new on/off parameter in the send bus module
- Midi-learn is now allowed on all the buttons of the navigation bar in IB mode
- better size adjustment when moving/resizing controls.
- new browser/Add-ons design
- new protect mode as hidden string
- better Audio to Midi (pitch tracker) sub-patch
- new Active Line Number module, to get the selected line in the grid
- new navigation bar design (IB mode)
- new Midi Expand voices Midi Tool script
- new Math/Bit Operators OR, AND, XOR, NOT, SHL, SHR available as scripts
- new improved Random Law Generator sub-patch
- new options in the global IB "maximize if ON (Grid & IB)" and "maximize if ON (IB only)"
- Usine graphic engine is globally twice faster.
- scripts take less memory
- audio protection in the Filter module to prevent instability
- new target parameter in the mouse module
- new SET_LAYOUT instruction in the IML
- new FaderColor Module.
- in the Sequenced Pianoroll, we can now scroll the cursor position.
- array's input in the XPpad module
- the internal help form has a Minimize button
- set array parameter in the random module
- inverse Y axis option in the layout of XYPad
- various design improvements
- array's input in the Draw Objects module
- up to 128 objects in the Draw Objects module
- new layout option to draw connexions between objects in the Draw Objects module
- parameter type ptPointerBitMap, ptPointer, ptLed added in scripts
- array's parameters are saved automatically in scripts except if SetDontNeedSave is called
- new 1-X and X+1 math modules
- new window parameter in the grain sampler module
- the Delay module sounds better.
- new Compile&Init and Compile&Reload menus for scripts
- few new IML instructions: PAUSE, CREATE_UID, GET_CAPTION
- VST Randomizor template added
- DrawTrajectory user module has been updated (thanks to Martin Fleurent)
[large]fixed bugs[/large]
- the Drag & Drop doesn't work in the sequencer
- various Drag & Drop issues in grid mode
- several important bugs in the VSTRandomizor script
- hard bug when updating VST parameter's list
- the SetVariableString doesn't work properly in scripts.
- various bugs in the random data module
- various glitches issues in the VST version
- problems storing Midi-learn's after copy/past of a sub-patch.
- problems with negative numbers in the RandomData module
- the 'edit layout' function is sometime tricky...
- various graphic refresh problems when the ASIO driver is down
- small refresh issue in the preset panel on recall
- sometime Midi/Key learns aren't properly stored in the patch
- often, the Midi setup is lost...
- the Midi Sequencer diplicates Midi Events in bar mode
- various conductor issues with copy/past bank
- refresh problem when a VST window is reduced as a thumbnail
[large]comments[/large]
- the scale parameter of Faders/Knobs is no longer in the layout settings but is now in the module settings (as it use to be in the V4)
- the color selector is now opened with a double click instead of single click.
- midi/key learns can be lost from previous Usine versions
fnatic99
Unread post by fnatic99 » 15 Sep 2010, 22:24
keep up the good work mate :cool:
Floego
Unread post by Floego » 15 Sep 2010, 22:58
Thank you! :)
Unread post by nay-seven » 15 Sep 2010, 23:05
and others hidden bonus...
thanks sir !
Unread post by bsork » 15 Sep 2010, 23:34
:cool: Thanks!
ethnix73
Unread post by ethnix73 » 15 Sep 2010, 23:36
Thanks mister senso!
Seb.Dub
Floego
Unread post by Floego » 15 Sep 2010, 23:41
senso wrote:- in the Sequenced Pianoroll, we can now scroll the cursor position.
How is that?
Unread post by senso » 16 Sep 2010, 09:54
@floego
see http://www.sensomusic.com/forums/viewtopic.php?id=2343
a frank suggestion :
- possibility to move the head player in the piano roll in sync with the sequencer , click on ruler bar (actually not possible).
Unread post by 23fx23 » 16 Sep 2010, 21:42
nay-seven wrote:and others hidden bonus...
thanks sir !
yup as always, like the colors lum gradient by default, very cool.
GDLive
Unread post by GDLive » 23 Sep 2010, 15:22
Nice, easiest use with this version ! :)
Users browsing this forum: No registered users and 148 guests
