"auto on "
headphoner
Unread post by headphoner » 03 Sep 2010, 14:28
I would like that usine is automaticily in "on" position when i open it.
I really don't know how to do it, so i need some help "HEEELPPP!" :)
In fact i made a workspace for an installation, I will not be present so people must only have to start the computer .
Unread post by nay-seven » 03 Sep 2010, 14:51
open your master insert patch , add a switch to the inlet ON of a Dashboard module ( module/interface control/usine panels/ )
put it on the on position of course an save your workspace...
headphoner
Unread post by headphoner » 03 Sep 2010, 14:56
Thanks a lot!
Of course it's very simple.
Unread post by woodslanding » 04 Sep 2010, 09:17
okay, this works (great!) but I'd still like to be able to turn usine off from the dashboard.
If I put an 'only if changed' module between, it doesn't work on startup.... I guess the starting state of the button isn't a 'change'
Unread post by nay-seven » 04 Sep 2010, 11:53
there's certainly simplest but here a workaround :( put this in your master insert too of course )
ethnix73
Unread post by ethnix73 » 04 Sep 2010, 12:25
or this way maybe:
Seb.Dub
Unread post by nay-seven » 04 Sep 2010, 13:33
well done ethnix !
Unread post by woodslanding » 10 Sep 2010, 08:55
oh, nice--that will do it, that's great, thanks!!!
Now the only other startup issue I have--I'd like the IB to open in fullscreen. I know you can set a keycommand to the fullscreen button, but is there any way to address it programmatically??? maybe via usine message?
thanks!!
-e
Unread post by nay-seven » 10 Sep 2010, 11:05
first use midi learn on the + button
then use the same CC number like this ( here =cc 23 ) and add this to ethnix patch :
Unread post by 23fx23 » 10 Sep 2010, 11:14
yeah well done nay!!!!
Unread post by woodslanding » 10 Sep 2010, 19:39
I haven't tried 'send midi to usine', I thought of key learn, but not midi learn.....that looks great, thanks!
Unread post by woodslanding » 10 Sep 2010, 20:40
okay, maybe I have never used 'send midi to usine' because I can't find it!!
can't find 'x+1' either....
I'll check the wiki.
-e
Unread post by nay-seven » 10 Sep 2010, 20:48
you know that 's there is a search engine in the browser , right..? :D
Unread post by woodslanding » 11 Sep 2010, 05:46
It's not finding x+1 any better than I am. But it's a good feature to know about!
I'm having the problem that I don't want auto on or automax when I'm patching and testing with usine, only when I'm performing.
I'm going to see if it works to put it in the wkp somewhere instead of the master. In fact, I'm realizing I don't want to put much of anything in the master. I never realized that the master is not saved as part of the wkp. This means, if I change it while working on one wkp, it may break others. So I'm going to keep everything out of it for now!!
Okay, more tests. I guess this only works in the master, because the other channels are off, and can't respond to the 'on init' command.
It makes me wish there was an option to save master settings with the WKP...... is there a reason this isn't done???
Unread post by nay-seven » 11 Sep 2010, 11:31
about the x+1 are you sure you are in the module tab...?
cause no problem here...
about your problem: if you keep only the auto on in your master you can add this in one of your active tracks :
Users browsing this forum: Bing [Bot], Google [Bot] and 557 guests
