A really interesting application to route midi and more : Copperlan
Unread post by nay-seven » 29 Aug 2010, 22:32
I've discover this freeware application recently and i can't work without it now, so time to share..
in a few words :
you use different midi controllers ?
you have a local network between some computers ?
you use computer 1 with a touch screen as remote to computer 2 ?
what his team say :
CopperLan is a networking system for command & control and streaming management that brings about a comprehensive solution to linking and interfacing pro-audio and musical equipment.
Its powerful virtual network definition can be applied to any physical transport specification present or future as well as running inside a computer, merging all participating members in a single pool.
compatible : PC ( xp,vista,seven ,32 and 64 bits ) MAC-OS X (Mac Intel).
i 've found many uses with Usine..
1: only one computer , several midi controllers , route via some of copperlan virtual cable , if you want to add a new controller you forget to plug for example , you plug your midi device , it's appear in copperlan and you can route it directly without restart Usine
Settings window :
2: local network of some computers : your midi controllers can be use with all of them without plug/un-plug them each time :
here an example with my bcr 2000 , route to 2 of my computers ( here named musik1 and yan-fixe)
Connections :
also useful with touchscreen as midi remote ..
and many more to discover..( SDK for devellopers , high resolution for Musicality..)
overview on their website
french blog
ethnix73
Unread post by ethnix73 » 29 Aug 2010, 22:57
Interesting nay-seven!
Thanks for the link...
Seb.Dub
Users browsing this forum: No registered users and 317 guests
