OSC ?
multiphone
Unread post by multiphone » 26 Aug 2010, 16:58
i have a simple question about OSC conection.
I see the OSC info enter in the console of Usine but i dont see this infos in the OSC receive module...
I forget something ?
HB
Lines / Points / Squares
http://www.hervebirolini.com/
Unread post by 23fx23 » 26 Aug 2010, 17:13
are ya sure the good adress is entered in module? check also port in osc setup.
multiphone
Unread post by multiphone » 26 Aug 2010, 17:34
hello 23 fx,
Thaks for reaction.
The right adress in the module ? If i have 0.0.0.0. or 169.254.137.125 is the same : No entry...
In port in the OSC Setup is...???
Thanks in advance.
HB
Unread post by nay-seven » 26 Aug 2010, 17:42
hello hervé
the adress for osc is what you see in the console , by default , it's Usine , depending from what device you send OSC
here an example :
about the port , it's the same problem: your device ( for example an ipod )must send OSC on the same port than Usine ( by default in the osc setup window = 8000
multiphone
Unread post by multiphone » 26 Aug 2010, 18:01
Hello Nay Thanks to take time...
But as allway i feel i'm a big nozzle ;-)
So,
The info get in the console from 169.254.137.220:/accxyz (fff)
so i type 169.254.137.220 and remplace /usine/ ???
i'm lost in OSC ;-)
HB
Unread post by nay-seven » 26 Aug 2010, 18:18
we all have begin like this with Osc , don't worry
first ,don't worry with ip and try to just to replace /usine/ by
/accxyz/
must be enough
multiphone
Unread post by multiphone » 26 Aug 2010, 18:33
rrrrr....
no effect !
Strange !?
HB
Unread post by nay-seven » 26 Aug 2010, 18:46
mmm, my fault try also without the last /
if not , can you try to make a screen capture of you osc console
here mine ( i've disable osc here to stop message,
click on one message to see details in the lower window and be careful you don't have adress like
/2/accxyz
or something like this...
multiphone
Unread post by multiphone » 26 Aug 2010, 19:15
Here it is...
I think after that we need to write a short wiki for OSC basic problem
HB
Unread post by senso » 26 Aug 2010, 19:23
the valid osc address is
Code: Select all
/accxyz
senso+++
multiphone
Unread post by multiphone » 26 Aug 2010, 19:55
OMG !
Thanks Senso !! And Nay for your advices.
I dont know wath apend but it works... i enderstand the valid osc adress now.
Thanks a lot.
HB
Unread post by nay-seven » 26 Aug 2010, 20:05
cool+
