hello again,
Is it possible to quantize a steps module output with the quantize swing it patch? The way I have been doing it is by using a "pass" module on the steps output and quantizing the trigger flow but it doesn't seem to be accurate enough because while the trigger is quantized the step values are not which creates some inconsistencies in the output. maybe there is another way?
swing quantize steps module output values?
maybe inverse the problem and quantize directly the step module ? :
very cool solution. i didnt think of that. but one problem, how to ensure that the steps is synced to each cycle?
if you want restart the step module each cycle you can use the outlet of the master synchro inside the sub patch clock beat
and link it this way :
Users browsing this forum: No registered users and 120 guests
