New version (2.8). Major Update
Announcements
Unread post by senso » 31 Mar 2007, 16:16
Usine 2.8
New features
? Vista compatible.
? Dual Core Optimization.
? All controls can be displayed in a resizable window (wave display, Pianoroll, etc.)
? Interface builder: to build personal interfaces and display only the controls you want to see on the screen. (see Interface Builder example in the demo folder)
? Loop range selection in the Wave Display module.
? A Browser window (replaces the old menu).
? Record time adjustment in the sampler form up to 600 seconds
? Usine can handle strings (text) flows.
? Change the color of a patch.
? Multi selection (cut, copy & paste), in patch edit mode.
? New ?Continue? button in the sequencer, to play the current loop and pass to the next.
? Quantization option on all buttons and switch: quantize on cycle, bar, beat, etc?
? Quantization option on conductor lines.
? New interface design, more clear and compact.
Improvements
? No more audio clicks when you activate a patch in the grid (small cross fade).
? No more audio clicks when you change the loop size in the sampler.
? Channel filter inlet in Midi filter Module.
? Change Channel in Midi transform module now works for all Midi messages.
? The Key learn mode can be ?global? or ?only on the selected track?.
? Allows multiple Midi remote devices.
New modules
? Only if has changed: passes a flow only if its value has changed.
? Pass Event Flow: inverse of Stop Event Flow.
? Array In sub-patch inlet.
? Array Out sub-patch inlet.
? OSC send string.
? OSC send 32 data?s.
? OSC receive 1, 2, 4, 8, 16 data?s.
? Patch Active: enables or stops the calculation of the current patch.
? Vertical Fader (in the interface builder).
? Vertical audio Vu meter (in the interface builder).
? Text Field: set or display strings.
? Image, Picture.
Compatibility notes
The Grain Sampler inlet order has changed and is no longer compatible with the 2.64 version. Please check your patches if they contain a Grain Sampler module.
Fixed bugs
Midi Time Clock message now received.
bobsled
Unread post by bobsled » 31 Mar 2007, 16:52
Looks great, Olivier! When will the full version be available for download? (I see the free version has already been posted.)
mahtazz
Unread post by mahtazz » 31 Mar 2007, 17:18
Chapeau, Monsieur!
Should we, registered users, wait for a e-mail with direct download link or we'd download the demo version?
Thanks!!!!
Miquel.
Unread post by senso » 31 Mar 2007, 18:44
hello,
I'm sorry to tell you that the new version will be available for free only for the "normal licence owners" (as a free update).
It's a terrible decision because I know that most of early donators, like you, are very implicated in the Usine project.
I'm sure that you will understand that I really need more contributions: buy computers, pay for someone to help me, etc.
I want to keep this soft as cheap as possible that's why I need your contribution.
Thanks a lot.
bobsled
Unread post by bobsled » 31 Mar 2007, 19:31
Could you tell us what "normal license owner" means?
Dozius
Unread post by Dozius » 31 Mar 2007, 20:15
Will there be a cheaper update fee for 'early adopters' or do we have to pay the whole 50? to get Usine back?
rods
Unread post by rods » 31 Mar 2007, 20:38
I understand that...but maybe a special price for us that have already donated something before...discount the donated value?
When v3 is released should we pay again, 50? now for v2.8, and more for v3 upgrade?
Thanks.
Rods
Vonbrucken
Unread post by Vonbrucken » 31 Mar 2007, 21:22
thanks for the info !!
Unread post by senso » 31 Mar 2007, 23:23
I'm confused about this discussion, and I don't like to talk about money.
It's the first upgrade since one year.
Do you really think that 50? per year is too expensive?
Unfortunately, too complex.
I will turn Usine licence into something more clear. The best way I found is to pay for a normal licence and then for upgrade. Finally like almost all soft...
But try to keep it very cheap and keep the free version available.
rods
Unread post by rods » 01 Apr 2007, 00:19
I REALLY understand your point. The reason that made me donate some money in the first place is the same reason I have to buy the complete version.Your work in usine is fantastic.Usine is really impressive.
I was just tryong to understand things clearly. I'm not using usine in the 2 or 3 months, so I was just thinking in waiting for some v3 anouncement in the near future...just gessing...
Thanks and sorry for the confusion.
Rods
Dozius
Unread post by Dozius » 01 Apr 2007, 01:35
senso wrote:Unfortunately, too complex.
Ok, I was just wondering. This update is fantastic, I'm glad to see the palette suggestion I made has been implemented. Lots of great new features. I'll start saving up my pennies for a new license, in the meantime the very generous free version will fill my tinkering needs.
I was going to ask about possible academic pricing (college makes me poor) but less than $80 CAD is already affordable enough I think.
I hope I didn't come across too negative. I really love what your doing here. Thanks for the great work!
Vincent
Unread post by Vincent » 01 Apr 2007, 05:21
Hi guys!
You won't believe me: I just did not go to sleep cause i wanted that new release.
Well, I know what means money probs, I really know. But here, considering Senso's huge work, it seems to me somewhat out of place talking about money.
This 2.8 is great. It does so many things and so well. That price could even be twice it would stay a too-low-price and I hope we all know that.
I had to kill my mother for the third time to obtain some money for Usine, and I don't care going to hell, because here it's just paradise. And I agree with you that the first kill is the harder, but, well... No kidding, guys!
Now let's play music, Okay?
Sorry for my words...
Regards.
Unread post by bsork » 02 Apr 2007, 00:56
Once again Olivier has done some great work, and I actually think that the new version deserves to be called it 3.0 instead!
Vincent
Unread post by Vincent » 02 Apr 2007, 01:49
No-no. Version 3.0 includes private espresso. To early to talk about.
roby
Unread post by roby » 02 Apr 2007, 21:27
Good news. Can't wait to become a gold member. Usine has grown into an impressive tweaking device, and I'm happy to give my support if it means we will all get more amazing features.
Unread post by bsork » 02 Apr 2007, 23:09
If 3.0 has the espresso option, I presume 4.0 will contain a virtual cocktail piano?
(I usually go straight to the forum page, but just now I had a quick look at the news page. I wondered whatever a "glod member" might be, but thanks to roby I understand that it's a typo for gold member.)
Unread post by senso » 03 Apr 2007, 15:27
the next step is to become a God Member...
Vincent
Unread post by Vincent » 05 Apr 2007, 04:52
bsork wrote:I presume 4.0 will contain a virtual cocktail piano?
Yeah. I don't mind to become a God Member if there is cocktails.
waolelaid
Unread post by waolelaid » 07 Apr 2007, 03:36
hello Olivier I'm agnostic how can I do ?
are we obliged to buy windows vista also ?
well I'm just kidding you work a lot
good morning
Friedrich Nietzsche
Vincent
Unread post by Vincent » 13 Apr 2007, 19:41
waolelaid wrote:are we obliged to buy windows vista also ?
No-no-no-no-no. Don't you mix up real gods with fakes?
Ah, those agnostics...
Welcome here, waolelaid. I hope you'll like the place.
stanlea
Unread post by stanlea » 14 Apr 2007, 00:04
Well ... I assume that a god member is never tired.
Sorry I couldn't resist. First post, bad joke.
You know my name (look up the number)
Vincent
Unread post by Vincent » 14 Apr 2007, 00:23
It's OK, welcome stanlea.
just one thing: this thread should not be on top of list!
Let's go an talk philosophy somewhere else.
Users browsing this forum: No registered users and 108 guests
