little question about cc curve from piano roll
damstraversaz
Unread post by damstraversaz » 18 Aug 2010, 10:50
Hi everybody
first sorry for my poor english...
I begin to use usine for midi and have a small question about cc curve from the piano roll.
I try to make a cc curve for the filter of helios , like a automation enveloppe ( ableton live, reaper, cubase etc...)
but it seems to be not possible to do smooth curve ( I try with normal and log scale for the fader) the filter jump to the maximum very quick. and the fader is on the "1" position, although the cc curve is just on 64.
can somebody help me ? thanks a lot for reading
damien
Unread post by nay-seven » 18 Aug 2010, 11:18
hello damien
the piano roll send midi information, no 0-1 values ( what is waiting the direct inlet of the HeliosII)
the Helios II don't have midi learn built in , so you can send direct CC midi but here a work around :
use the module send midi to usine( modules/input-outputs) and assign the same CC number to your knob ( via the remote panel in your patch ), works better this way..
( with others VSTI , at least those who have midi learn or midi assign , you can send CC directly by the midi in )
ask if any question
damstraversaz
Unread post by damstraversaz » 18 Aug 2010, 15:29
it works perfectly thanks a lot !
Users browsing this forum: No registered users and 83 guests
