Hi Olivier.
When you paste a module in a patch editing window, it takes the same place it had where you copied it (well, plus a few pixels shift, good).
But, sometimes, guys like me move a lot their workspace, adding module here and deleting others there, and there is nothing to know where we are according to the modules coordinates after a long evolution. So, sometimes, when I paste something coming from an other Patch, it takes me minutes to find it in far outlands and minutes to find again the "civilization". Or, if don't find it, minutes to undo the paste operation, as undoing is sometimes very long too.
Maybe a simple X/Y ruler? Or paste objects in the visible part of the workspace? Or paste where you click? Compass and survival blanket?
Other suggestion: Add an output to the Preset Module. It can be sometimes interesting to link Presets with SenToAudio&Data Bus. What do you think?
Module pasted, but where?
- senso
the copy/paste works better in the new version.
Also new: the multi- select/copy /paste.
- senso
not stupid and also very easy!
next release.
next release.
- senso
I'm confuse your last post has been deleted by mistake.
sorry I can't restore it.....
