Usine Distortion On Audio Through?
caco
Unread post by caco » 05 Aug 2010, 11:50
Hello Olivier,
I am using the VST version of 5.2 of Usine Free and was wondering why so much distortion on audio through? The images are from Christian Budde's VST plugin analyszer using identical settings for energyXT1.4 and Usine. EnergyXT looks as expected where the 1k test tone passes through unchanged. However, with Usine there is serious aliasing. Have I set up Usine wrong? I just loaded Usine and used the default patch.
Unread post by senso » 05 Aug 2010, 12:13
We don't know how this analyzer proceed so be careful! And it sends strange blocs to Usine.
If you set the vst buffer size to 0 every thing is normal.
In this case, it's a buffer size problem which generate an hard distortion.
More generally Usine has a 'totally pure' audio thru.
caco
Unread post by caco » 05 Aug 2010, 12:23
You are correct Oliver, i have changed the vst buffer size to 0 and all is fine again :)
What is the vst buffer and what does setting it to 0 actually do?
Unread post by senso » 05 Aug 2010, 12:31
it adjusts the latency in multicore environments.
Users browsing this forum: Google [Bot] and 12 guests
