Very impressed but I have some questions....
maydaycapsize
Unread post by maydaycapsize » 17 Mar 2007, 22:53
Hi just wanting to let you know that I am very impressed with usine.
I tried it about 6 months ago but couldn't get sound out effectively.
I downloaded the free version a week ago and it is amazing and it seems rock solid too. I'm used to using 'Buzz' so I'm used to lots of crashes.
Great software and I think it is exactly what I'm looking for for live use...
I actually really like buzz (even for live use) but it is so buggy that it would be like playing russian roulette.
but I love the modular side to usine....actually from what I've seen I'm loving every part of usine
I'm still getting my head around it though and I have some noob q's
Simple Q------ Basically what Iwant to do is to have loops (wavs) playing and skip to the next loop at a button press.....
i.e. when I press 'next' or whatever the current loop keeps playing and when that loop is finished it will go to the specified loop/ part
I assume this is using the sequencer or the conductor-
whenever I use the sampler and set it to sync- cycle
it doesn't finish playing the last sample but is just silent until the next sample....
And with conductor I don't understand how to add sections effectively --- I've read the help section......
are there many online tutorials available
Hope you can help
maydaycapsize
Unread post by maydaycapsize » 19 Mar 2007, 09:25
Thank you I will try it out
Unread post by senso » 19 Mar 2007, 21:07
welcome to Usine forum.
I think that your problem can be solved with a single patch and sampler module.
Many solutions.
Better than a long speech, take a look on
http://sensomusic.com/download/examples/PlayNext.pat
(made in 5 minutes)
I hope it will help you.
maydaycapsize
Unread post by maydaycapsize » 19 Mar 2007, 22:20
Sorry
Am I a complete noob or going crazy.....
When I opened the playnext file
It seemed like an empty patch to me....
Or am I missing something
Unread post by senso » 20 Mar 2007, 08:53
sorry,
the patch was saved with a newer version.
Now patch works.
maydaycapsize
Unread post by maydaycapsize » 20 Mar 2007, 12:16
Thank you
Simple but great....
Cool
Users browsing this forum: No registered users and 338 guests
