Modulo that outputs float?
CLeRIK
Unread post by CLeRIK » 26 Jun 2010, 19:48
Hi!
I just noticed that the module "A mod B" outputs the integer remainder. What's the easiest way to get the float reminder? I guess it would be pretty easy to create a patch that does this?
CLeRIK
Unread post by CLeRIK » 26 Jun 2010, 19:56
I just solved it, but it doesn't look very pretty :)
Unread post by 23fx23 » 26 Jun 2010, 20:00
what i do usualy is multiply all by 10, 100, or 1000 (the in, the mod, and out of mod) not pretty either..
wonders if there is a better teck.
Unread post by 23fx23 » 28 Jun 2010, 17:07
oh yeah mean that outputs real floats, with int mod. well done,nice, not that weirf. thanks.
between can also use trunc instead of DIV 1, equivalent here.
Users browsing this forum: No registered users and 113 guests
