sampler loop crossfade
Hello usine masters,
I am wondering if it is possible to have a crossfade on the loop points of a sampler. I have tried routing the "restarting" indicator of the sampler into an ADSR but it seems the loop is restarting too fast for the envelope or maybe the block size. I cannot use the zerocrossing feature of the sampler because the loop is tuned and when this is activated it messes up the tuning. I am using the loop function of the sampler as a sort of oscillator with a very short loop which its length is being modulated by some math calculations based on sample length to convert milliseconds to frequency which enables me to "tune" the loop to different pitches based on loop length. which makes a nice "raw" sounding oscillator but unfortunatly there can be some nasty clicks from the loop points. But if I am able to fade in the start and fade out the end of the loop it will sound nice. any suggestions? thanks.
maybe not the most elegent solution, but what about using two samplers with the same sample loaded, the same length loop and linked master controls The gain for each sampler could be triggered perhaps with use of some logic and math module to have one sampler fade out at say 90-100% and the other sampler to fade in at say sample position, at say 0-10%. A smoother might come in handy here. If I were sitting with Usine in front of me I would try to make a working example...
hehe soundmind you still play around with usine bloc limits, remember it's not a synthetiser hehe, not sure but maybe this
can give you better results:
you ll need one ramp up at start and one ramp down for end, problem when using restart pulse is that it could work for fade in,
but not for fade out, cause the envellope/ramp would have to be triggered Before the pulse.
I would try to use Ramp module instead of enveloppes that generate arrays you can multiply the audio with to get like an enveloppe, but i think they are more accurate
so a ramp Up triggered on restarting pulse,a rampdown trigered a small amount of time before sample end,either using a time counter,or something linked to percent.
or can cheat make it triger on loop restart, but slythly delay audio,so it's phase offsetted and you make booth down and up ramp one after the other (a V short volume down and reup , trig by loop end, but as audio is delayed the midle of v is occuring on end/start, where clic is occuring)
dk if im really clear hehe
or gurulogic solution ive just seen seems simpler and should work.
that is an interesting approach. I didnt think of modulating the gain on the sampler or using two samplers. I was using a volume module on the sampler output. I will try this. Maybe crossfading will be integrated in the sampler one day. which would then allow it to be used as a click free osc!gurulogic wrote:two samplers with the same sample loaded, the same length loop and linked master controls The gain for each sampler could be triggered perhaps with use of some logic and math module to have one sampler fade out at say 90-100% and the other sampler to fade in at say sample position, at say 0-10%.
Thanks for the reply master 23. Yes my brain keeps trying to use usine as a synth and i know it is ALMOST possible all that is needed is some minor additions to the sampler module and we have very versitile oscillator. As a matter of fact I am already using it (sampler) like a synth and it makes some very characteristic sounds with the sampler loop point method described above. The ramp crossfade method you describe sounds like a good new approach to this issue. I will try. thanks for the info!
After much experimentation I have concluded that the problem is unavoidable because of the loop being "too fast" to have data triggered at the same rate. after trying both methods it made even more noise which sounded far worse than the noise without the fades. However the sound that this experimental loop osc creates without the fades has a certain raw characteristic sound which is very usable. maybe i will post an example to inspire further development. I see a lot of potential for usine in this area because the samplers are very versatile and extremely CPU friendly. I believe it can be the answer to the question of a native usine osc and much more! Thanks for all the help.
could be a participative project ..?
here a little try too , too way by freq and by midi
synthesis_by_wav_test3and4
its good to have you on board master seven. I will check your example.
Here is a simple mono synth with an integrated slicer and sub slicer to select sections of the sample to use as the osc. the pitch is modulated by the loop points instead of the traditional sample pitch method. This allows you to take any sample or loop and use any section of it as an osc and pitch it anyway without losing the tonal character of the original sample. Works best with drum loops because the slicer works by dividing the loop into equal slices which makes it easy to select individual drum hits for use as the osc loop http://sensomusic.com/forums/uploaded/usinth.pat
nay-seven: Your patch was interesting. I forgot about using the grain samplers speed mode to "freeze" the sample. This is a great way to make an osc. This demonstrates yet another way to "synthesize" sound with the samplers. thanks for the example.
yep, 2 different method for radically different results !
and that 's why it's interesting !
your 's sound really near a classic osc and it's an inventive method
congrats !
pfuu , a life will never be enough...do you think cats can use Usine..?
congrats !
Usine is deceptively simple. Yes there simply isn't enough time to try every single possibility.
Users browsing this forum: No registered users and 120 guests
