interface items do not stay in place
soundmind
Unread post by soundmind » 14 Apr 2010, 06:18
please forgive me if this is already known. When editing interfaces in the IB especially in a complex patch the interface items jump all over the place and some loose their position entirely when editing the patches panel position or the size of the panel in IB. it seems like the IB gets confused sometimes. maybe a "super lock" is needed to super glue them in place. anyone else notice this behavior? thanks.
Unread post by senso » 14 Apr 2010, 08:51
the position can be lost if you manipulate the "where" inlet otherwise it's more a bug.
I'll check it.
soundmind
Unread post by soundmind » 14 Apr 2010, 10:35
understood. thanks.
Simonaki
Unread post by Simonaki » 15 Apr 2010, 05:13
Hello !!!
It's very disturbing when you pull ten buttons one stroke on a vst or other things and come back to the grid and just see 1buttons hidding all over... it can't be usefull to choose how buttons and faders arrived on the grid ...Just on 1 point or one after the other...
It's just a suggestion, a kind of usine v4 and v5 ?
Very best
Senso: Mes collègues des Qwartz, étaient très contente de te rencontrer et encore bravo pour la performance Art-informatique...... A bien tôt....
Unread post by senso » 15 Apr 2010, 08:55
By default new controls are located in the upper-left corner.
It's the main drawback of the V5 but the advantage is that, unlike the V4, you can locate your control where you want.
@simon: très sympas tes ami(e)s et ta soeur.
Unread post by woodslanding » 21 Apr 2010, 09:07
one prob I just noticed, is that if you move an object in the IB past the left or top edge (which extends the IB area) invisible panels do not get adjusted along with the visible ones.
For me, I have lots of panels occupying the same area, but only one is visible at a time. All the invisible ones don't readjust to the new left and top edges of the IB.
A small bug, but one I have to be VERY careful with, or I will be spending a lot of time realigning containers.
Simonaki
Unread post by Simonaki » 25 May 2010, 16:15
Hy dear community
Te same problem, very hard to pull buttons and tidy up it,
Is it possible that we can move buttons as we like with unlock mode but when we create new buttons or fader appears in the low of the window... When we're in the sub patch The place of fader and buttons definite height of input order...
I've some crash of usine when i'am load vst at same it's playing...
Some time the asio make bug on the screen of setup...
any suggestions???
ErotiCore SteNch
Unread post by ErotiCore SteNch » 13 Aug 2011, 22:39
i thought i would post this idea/suggestion in this topic instead of making a new topic,as its related
maybe this could be solved with some sort of snap-to-grid system??
Ariajazz
Unread post by Ariajazz » 21 Oct 2014, 18:49
I found this thread browsing the web because I'm having the same problem with USINE STAGE 5.80, items just don't stay in place in IB mode. I know its been 3 years from the last post but I wonder if it is an effective way to LOCK item position in IB or if it is just a bug. It is very annoying since I spend too much time arraging items for complex patches in IB. Thanks.
Unread post by nay-seven » 23 Oct 2014, 12:18
have you check that the IB layout has not the re-organize = automatic...?
