faders---max above min?
Unread post by woodslanding » 29 Apr 2010, 09:15
If the max could be low and the min high, it would totally make working with drawbars 1000 times easier.....
(Still struggling to get the vst param script to work with reverse faders....)
La Tenaille
Unread post by La Tenaille » 29 Apr 2010, 09:20
+1
I was thinking about posting this one.
gurulogic
Unread post by gurulogic » 29 Apr 2010, 09:54
Wouldn't that be done like this? Or am I missing the point...
kara wrote:Fader with min 0 and max 100 goes to an (A-B) module where you set A=100 and B the input of your fader.
Is that what you want ?
k
Unread post by 23fx23 » 30 Apr 2010, 00:05
another might be simple in some cases workaround: inverse fader and baground color gives a visual inverted fader, keeping normal wiring, or flip the jpg sequence image horizontally if jpg based..
Clearscreen
Unread post by Clearscreen » 30 Apr 2010, 03:04
It'd be nice to be able to rotate elements in the IB - I've thought about that before...
Unread post by woodslanding » 02 May 2010, 07:10
Yeah, I've been able to work around everything (Lots of ABS(1 - x) everywhere)
except sending IML.
Still haven't figured that out. And maybe switching the fader values wouldn't help anyway.
jeanrene
Unread post by jeanrene » 07 May 2010, 19:03
127 - (0->127) = (127->0)
(0->127) is the fader
127 - a box "-" in math, "127" in "a" and "fader" in "b"
(127->0) is the result (invert fader)
I post this patch the next week, good weekend
PatcherKit at work.
jeanrene
Unread post by jeanrene » 08 May 2010, 11:05
"REVERSED FADER" exemple is in add-ons pack (PatcherKit) in Data tools
PatcherKit at work.
Unread post by woodslanding » 09 May 2010, 08:14
Thanks jeanrene--I'm sure that will be useful.
I don't have problems reversing faders, though. My issue was addressing reversed faders via IML.
I figured that one out also (well, Bsork did most of the work!) and will post it, although it is quite a complicated solution.
-e
Unread post by bsork » 09 May 2010, 21:49
woodslanding wrote:I figured that one out also (well, Bsork did most of the work!) and will post it, although it is quite a complicated solution.
-e
...uh... I did?
Unread post by woodslanding » 10 May 2010, 06:38
Ummm.... I think it was you (?)
Unread post by 23fx23 » 11 May 2010, 17:43
i think it was me but no worries ;)
Unread post by woodslanding » 12 May 2010, 22:27
oop, sorry :/
Users browsing this forum: No registered users and 107 guests
